Activity Forums VEGAS Pro copying effects
  • copying effects
    Posted by Kgb on July 25, 2005 at 11:25 pm
    I tweaked a clip with several effects and liked it so much i wanted to use the same effects on the entire video. Is there any way to copy the effects from one clip onto the entire video (i know you can add effects to the whole video by dragging them onto the preview box, but I dont want to have to set the parameters of each effect all over again)
    Gary Kleiner replied 21 years, 1 month ago 2 Members · 1 Reply
  • Gary Kleiner
    July 25, 2005 at 11:53 pm
    Save the FX Chain using the Plug-In Chooser (where you add the FX from) using Save As. You will then be able to add that combination of FX, with their settings, in one step.
    Gary
