Activity Forums Adobe After Effects Copying and pasting
  • Copying and pasting
    Posted by David Yowell on August 8, 2009 at 1:45 pm
    I have a project where I have quite a few comps. In the first comp, I have a screenshot that has quite a bit of movement and requires many keyframes. I need to duplicate these movements with about 15 other screenshots. I am making all of these screenshots individual pre-comps and then will put them together later. Is there a way to copy and paste these keyframes into other comps? Thanks in advance for the help.
    Dave Johnson replied 17 years, 1 month ago 3 Members · 2 Replies
  • Todd Kopriva
    August 8, 2009 at 5:07 pm
    Yes, you can copy and paste keyframes from one layer to another, even if the layers are in separate compositions.
    If the animations that you’re copying and pasting are more complex, or if you think that you’d like to save them for later use, you can save them as animation presets.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Dave Johnson
    August 11, 2009 at 8:46 pm
    Perhaps there will be something in the posts below that’ll give you some ideas … along the lines of making multiple copies of a comp (or entire project) instead of the risky and less reliable method of copy and paste.
    Re: Replacing footage – making clip independent — NOT globally changed
    by David Johnson on Aug 7, 2009 at 9:21:36 am
    in the Adobe After Effects Forum
    https://forums.creativecow.net/readpost/2/962028
    Re: Replace entire PSD file in AE
    by David Johnson on Jul 24, 2009 at 11:53:44 pm
    https://forums.creativecow.net/readpost/2/961578
