Activity › Forums › Apple Final Cut Pro Legacy › Copying and pasting clips to specific place in sequence
Posted by Jason Noto on January 10, 2007 at 8:54 pmHello,
Does anyone know how to copy a clip (audio or video) and place it in a specific place in the sequence i.e specific tracks and in and out points
Thanks. I appreciate any insight and info you are able to share
Jason
John Steventon replied 19 years, 7 months ago 4 Members · 4 Replies -
Ben Insler
January 10, 2007 at 9:09 pmClips paste into your auto selected tracks, which you can turn on and off by unchecking the little intersecting rectangles found just to the right of the lock icon for each track (on is dark gray, off is light gray). Video and audio will both paste into the lowest numbered auto-selected video tracks. If all auto selects are on or off for video/audio, your clip will paste into the track you copied it from.
Best,
Ben
John Steventon
January 11, 2007 at 3:33 pmRemember the clip will paste in where your timeline bar indicator thingy is too.
And, you’re having problems copying and pasting just a part of a video clip, and don’t want the audio to follow, you could just try using the blade tool at your in and outs to make that clip separate, select it, copy it, and then paste it elsewhere (after ‘joining through edit’ to repair your cuts). This is what I did before someone enlightened me about the auto-select buttons. (which is a heck of a lot easier way to do it!
John Steventon – Author of DJing for Dummies
Success is merely a failiure to imagine more…
G5 2.7Ghz, 4.5Gb ram, Blackmagic Decklink/multibridge, 5.6Tb Infortrend storage, FCP Studio 5.04, Makie MCU control, Yahama 5.1 surround, JVC DTV multi-format monitor, 2x23inch Apple monitors – and a partirdge on a pear tree.
Tom Wolsky
January 11, 2007 at 3:43 pmYou don’t need to cut the clip for selection. Use In and Out points and the auto select buttons to pick exactly what portions of the timeline, tracks and clips you want to copy, hen use the auto select buttons to control exactly where you want to place that material.
All the best,
Tom
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 2 Editing Workshop” Class on Demand “Complete Training for FCP5” and “Final Cut Express Made Easy” DVDs
John Steventon
January 11, 2007 at 4:01 pmYeah – that’s why I said that’s what I did before someone told me about the right way to do it! Just thought I’d give another way of doing the same thing.
