Activity › Forums › Adobe After Effects › copying and pasting AE layers
  • copying and pasting AE layers
    Posted by Chris Straus on September 9, 2010 at 8:12 pm
    simple question, but i have no answer. why does after effects reverse the order of layers when copying/pasting? eg. i have 4 layers, LAYER 1 (on top), LAYER 2, LAYER 3 and LAYER 4 (on bottom). I want to copy and paste those layers, but it pastes in as LAYER 4(top) down to LAYER 1 (bottom). is there a way to paste in the same order as copied? thanks.
    Andrew Brady replied 12 years, 11 months ago 3 Members · 3 Replies
  • John Cuevas
    September 9, 2010 at 8:29 pm
    AE copies and pastes in the order that you select them. Make sure you select 1, then 2, then 3 then 4..if you want them to stay in that order.
    Johnny Cuevas, Editor
    http://www.thinkck.com
  • Chris Straus
    September 9, 2010 at 8:34 pm
    sweet. thanks.
  • Andrew Brady
    October 21, 2013 at 4:37 pm
    yep once again you have the right answer for what i need .. cheers
