Copying a Shape Path to an Adjustment Layer Mask
Hi everyone!
I have created an animated rectangle on a shape layer and I want to copy the path of the rectangle to a mask on an adjustment layer. The shape is semi-transparent and I’m trying to create an adjustment layer below to blur the background under the shape. When I copy the rectangle path’s keyframes into the adjustment layer, for some reason the rectangle is coming out stretched and out of place. I wouldn’t mind moving it into the center, but I don’t understand why it’s vertically stretched and don’t know how to fix this (other than manually moving the points but then it might not be an exact match to the shape)! So… what am I doing wrong? Please see my screenshot – it’s hard to see the adjustment layer’s mask path because it’s dark green but it’s there :).
Thank you!
