Activity › Forums › Maxon Cinema 4D › Copy UV points from 1 piece to another within the same mesh
  • Copy UV points from 1 piece to another within the same mesh
    Posted by Michael Goldberg on September 20, 2017 at 5:27 pm
    Hello,
    I have a mesh with a bunch of tentacles. I’ve uv mapped 1 tentacle the way I want it, and now I’d like to simply copy the points of the (apprx 20 polys) first tentacle to the points for each of the other tentacles within the UV map. I thought I’ve done this before, but when select multiple UV polygons, the option to copy UV points is greyed out.
    Is there an easy way to do this, I thought I’ve done it before?
    Mike
    Steve Bentley replied 8 years, 12 months ago 2 Members · 1 Reply
  • Steve Bentley
    September 27, 2017 at 7:40 am
    I’m not sure if this what you are trying to do but you can cntrl drag (copy) the UV tag to another object that has the same geometry. Any maps you ad to that new objects will map the same way the original did.
