Activity › Forums › Apple Final Cut Pro Legacy › copy transition pastes at 1 frame duration
  • copy transition pastes at 1 frame duration
    Posted by Bob Flood on August 21, 2007 at 8:05 pm
    Hi
    whether i right click on a transition, or command c the transition, or option drag the transition, it pastes with only a one frame duration.
    so even though i have copied a 15 frame cross dissolve starts at cut , when i paste it its only 1 frame long
    and I have enough margin on both shots. and i have trashed my prefs, Adn this used to work fine.
    I have FCP 5.1.4 and QT 7.2 on a dual dual 2.66 intel
    anyone else seeing this oddity?
    thanx in advance
    bee eph
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
    Jeremy Garchow replied 19 years, 1 month ago 2 Members · 1 Reply
  • Jeremy Garchow
    August 21, 2007 at 9:08 pm
    you don’t have heads/tails on one of those clips.
    Try right clicking on the transition and choose end on edit for alignment.
    Jeremy
