Activity › Forums › Adobe After Effects › copy tracker data
  • copy tracker data
    Posted by Clyde Villegas on December 20, 2007 at 5:03 am
    I tracked four points on a footage. Now I want that tracker data to be copied to a matte shape I created (in another footage) so that the matte will travel the screen following the tracking data I created. Is that possible using AE7? How about AE CS3? Thanks.
    Clyde Villegas replied 18 years, 9 months ago 2 Members · 2 Replies
  • Darby Edelen
    December 20, 2007 at 6:03 am
    It sounds like you want to apply the tracking data as a Corner Pin on the Matte, this will stretch the corners of the matte layer to the attach points of your trackers. You should look at the AE help on Tracking for more information:
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS39F8DA65-BC90-4831-A91E-0FC2BD18733C.html
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Clyde Villegas
    December 20, 2007 at 9:55 am
    Sorry, I mean a mask, not a matte (are they the same?)
    Anyway, this is what I’m trying to do: I have two footages, one on top of the other. I drew a mask shape (a circle) on the footage on top. Now in the footage under, there’s this moving object that I tracked.
    The reason for the mask is that I want the footage on top to show only the area inside the circle (mask). Now I want the mask to move in the same direction as the object I tracked on the footage underneath it. Thanks.
