Activity Forums VEGAS Pro Copy to tape
  • Copy to tape
    Posted by Dave Turnidge on December 25, 2010 at 9:32 pm
    I attempt to back up my completed projects to tape. I have had nothing but problems with this since ’07, and version 8. Today 8 isn’t even working…
    I select my IEEE device (camera) and have Video at NTSC DV and Audio at 48KHz.
    No selections on the next screen (except the default of “Use project output rotation setting”)
    I select “Add test pattern leader”, and “Play 1 KHz tone with test pattern”.
    I select “Crash Recording” and click finish.
    I get a “Preparing to print to tape…” dialog.
    Now’s where it gets, um, fun…NOT. I get a number of results, none of which do what I am requesting.
    1) I get an error dialog that says my file has a bad name. BOGUS.
    2) It starts pretending like it is recording, but there is nothing showing on the camera.
    Any Ideas?
    Dave
    John Rofrano replied 15 years, 8 months ago 2 Members · 5 Replies
  • John Rofrano
    December 26, 2010 at 4:51 pm
    I haven’t printed to tape in a long, long while (several years) but I do remember that I would pre-render the entire video first (Shift+M) so that all Vegas has to do is output the pre-rendered video files. Alternately, you could render the project to a DV AVI file and then use the DV Capture tool to print the file to tape.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Turnidge
    December 26, 2010 at 7:33 pm
    OK, THAT raises another question – what do you do for backup? I backup my edited/completed project to tape.
    I always render my project to AVI. The reason I don’t uas the DV Capture tool is that it doesn’t give me the color bars… Maybe I just don’t need them?
    Thank you,
    Dave
  • John Rofrano
    December 26, 2010 at 9:12 pm
    [Dave Turnidge] “OK, THAT raises another question – what do you do for backup? I backup my edited/completed project to tape. “
    I back up all my work to external hard drives. The complete project folder so I can go back and make changes later if needed.
    ~jr
  • Dave Turnidge
    December 26, 2010 at 11:29 pm
    “I back up all my work to external hard drives. The complete project folder so I can go back and make changes later if needed.”
    So, you just keep the hard drives – forever???
    Dave
  • John Rofrano
    December 27, 2010 at 2:27 am
    [Dave Turnidge] “So, you just keep the hard drives – forever???”
    Yes, As long as I would have kept the tapes. Instead of a tape library you have a USB hard drive library.
    ~jr
