Activity Forums Adobe Photoshop Copy single path from layer with numerous paths
  • Copy single path from layer with numerous paths
    Posted by Robert Paynter on January 27, 2010 at 7:25 pm
    Using the pen tool I have drawn several closed paths. Creating a single path layer. I would like to copy just one of the paths to another layer without duplicating the mask and deleting the other paths. Is this possible?
    John Mensinger replied 16 years, 8 months ago 2 Members · 1 Reply
  • John Mensinger
    January 27, 2010 at 9:13 pm
    Robert,
    You’ve got some terms-mixing going on there, so I’m not certain I fully understand what you’re trying to achieve.
    Paths are not tied to Layers, nor do they intrinsically define a Mask.
    The Paths panel will “list” separate “work paths.” To copy from one work path to another, use the Path Selection Tool to select the desired path component(s), copy using Cmd/Ctrl+C. Then switch to another work path or create a new, empty one by clicking the New Path icon at the bottom of the Paths Panel, then paste using Cmd/Ctrl+V.
    To leverage an existing path on a different layer, simply target that layer with the path in an active state.
    John M:
    All of the vim with none of that annoying vigor.
