Activity › Forums › DaVinci Resolve › Copy settings across keyframes in color page
  • Copy settings across keyframes in color page
    Posted by Brandon Lanski on April 12, 2019 at 10:07 pm
    I have this (apparently) really bad habit of forgetting to soften my masks before tracking and animating them. So when I go to change my soft 1 value, I have to go to each keyframe to change it and for some reason, selecting the keyframes with a marque doesn’t seem to help. Is there anything I can do?
    Starting to regret animating my power windows using the auto keyframer.
    Marc Wielage replied 7 years, 5 months ago 2 Members · 1 Reply
  • Marc Wielage
    April 14, 2019 at 1:22 am
    Well… as long as the degree of softness is constant, you can apply that across all of the shots in the Keyframe Clip mode, you can increase softness with one overall adjustment. Otherwise, there are control surfaces that will let you jump to the next keyframe and manually adjust softness as required. If there’s dozens or hundreds of keyframes, then you have a real problem.
    I’m a fan of the “divide and conquer” method of manual keyframing, where I’ll set a start point, an endpoint, then jump to the middle, and then slowly go through the scene in small increments and see where I really need to drop in another keyframe to work effectively. I also find that the Highlight mode will show you very quickly when the edge is peeking out around or over the subject.
    Also, multiple shapes is often the best way to mask out people, particular heads, bodies, arms and hands. (And I tip my hat to Dan Moran of MixingLight.com for this idea some years back.)
