Activity › Forums › Adobe Premiere Pro › copy & paste markers
Posted by Jason Spencer on October 23, 2013 at 7:04 pmHey all,
I’m working on Adobe CC and I want to know if I can copy and paste markers in Premiere Pro? I have 2 sequences with markers, I want to combine the sequences (which are interviews) to start a radio cut, but on the new Radio Cut sequence there are no markers, just the video and audio clips. Is copy and pasting markers possible?
Thanks.
Graham Withers replied 7 years, 9 months ago 4 Members · 4 Replies -
Alex Udell
October 23, 2013 at 9:23 pmI don’t think so….
you might…
Throw a transparent or adjustment video layer (you can create this in the project panel) on your sequences that have the markers and add matching markers to this clip in the timeline…
that way you can copy it to another sequence and it will retain all the markers you set…
not fun….but a solution….
Alex Udell
Editing, Motion Graphics, and Visual FX -
Ht Davis
March 12, 2015 at 10:25 pmWhat do you mean, “Not fun”? It’s the way this type of edit was meant to be done. It’s usually not normal to move markers in such a fashion with old-skool edits, it’s just coming into the workflow. By adding the markers to the layer, it can be added non-destructively, and it can be edited the same way, while being reverted with a simple recopy of the original layers. Perfect for this kind of edit, and you can have the new sequences carry different frame rates. Bravo on the fix…
I’ve got a DEFAULT project that I saved with several adjustments etc in bins, I’m going to add a MARKERS bin with a default transparent layer for placing markers on, and then just copy that to each original sequence’s bin, so I can always have one to work with in that fashion. Rendering out the project should still yield the proper output to encore, and to a video file that allows for markers. You’re awesome. THX again. -
Graham Withers
November 20, 2018 at 9:52 pmAs this is the first hit that google brings up, I thought I’d note – Premiere now has an option to do this under the “Markers” menu – “copy paste includes sequence markers”
Props to Video Revealed for the tutorial: https://www.youtube.com/watch?v=3yndlLEi9_g
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
