Activity Forums Adobe After Effects copy & paste layer styles (as in photoshop)
  • copy & paste layer styles (as in photoshop)
    Posted by Sahaba on June 7, 2005 at 12:29 am
    Hi everyone. Is there a way to copy a layer effects in After Effects, and paste it into another layer to apply the exact same effects to that layer?
    Kind of like the option in photoshop where you can copy a layer style and paste it too in any other layer!
    Steve Roberts replied 21 years, 3 months ago 2 Members · 1 Reply
  • Steve Roberts
    June 7, 2005 at 12:37 am
    There are a few ways:
    1. Dupe (cmd-D or ctrl-D) the layer, leaving the dupe selected, then alt-drag (opt-drag) the new layer from the project window to the dupe layer. The dupe layer will be replaced, but its keyframes and effects will be left intact. This doesn’t work with text layers.
    2. Copy the effects from the old layer’s effects palette, select the new layer and paste. Not all settings will survive the paste — so check.
    3. Select the effect keyframes from the old layer, copy and paste to the new layer.
    4. Select the old layer’s animated properties (select the property names in the timeline), then animation>save preset, name it and save it. Next select the new layer, and animation>apply recent preset — the one you just made.
    That should get you going — option 1 might be the first to try.
    Steve
