Activity Forums Apple Final Cut Pro Legacy copy–>paste into new timeline changed footage?
  • copy–>paste into new timeline changed footage?
    Posted by Tony Gomez on November 7, 2010 at 3:36 am
    So I edited my entire video in SD 29.97 by dumb error… It was shot at 24P Pro Res 4444 on my canon 7D imported with the canon plug. I created a new timeline.. to paste footage.. into the new HD timeline.. worked great.. but what happened to my footage.. there not the same exact scenes i chose… hm.. I also noticed my video now ends at 4:44 when my original edit ends at 3:45.. Hmm.. what am i missing..FYI.. video is fully edited already.. FX… slow motion.. etc.. just in the wrong timeline
    Tony Gomez replied 15 years, 9 months ago 2 Members · 2 Replies
  • Dan Monro
    November 7, 2010 at 2:01 pm
    Your frame rate has changed. Since your original edit was 30 (29.97) frames per second, and your new edit is 24 frames per second, you need more seconds to see the same number of frames. I tried to do the math, it works out about right – 6 fps x the total number of seconds divided by 24 (fps) works out to 56 something…
    I’m guessing that FCP was also retiming your video for you – interpreting it at 29.97, so the timecode doesn’t match exactly the re-interpreted (24 converted to 30 converted back to 24) footage in the new sequence. I assume you had to render it?
    I haven’t actually done this, but you could try removing attributes (right click) and see if you have speed changes. But you may have to re-edit. Not sure…hopefully someone smarter will weigh in with the quick fix.
    Your other option is to export your finished 29.97 cut as a quicktime and convert that. What is your delivery format?
    Good luck,
    D
    Dan Monro
    FCP, Avid, AfterFX, Atlanta
    MacBook Pro 2.53 GHz Intel Core i5 4 GB ram
    Mac OS X 10.6.4
    NVIDIA GeForce GT 330M
    Final Cut Pro 7 Quicktime 7.6.6
    – OR –
    2 x 3.2 Quad Xeon; 16 GB ram
    Mac OS X 10.6.4
    NVIDIA Quadro FX 5600 Final Cut Pro 7.0.2 Quicktime 7.6.6
  • Tony Gomez
    November 18, 2010 at 3:12 am
    thanx for you help.. ..what I did was this.. Selected entire sequence..
    chose.. from the menu sequence—> nest items.. then pasted it into the new timelie.. and it worked fine..Now when I export at current settings.. it does give me the entire exact 1920×1080.. Don’t know if this was the way.. but it worked.. was this the correct way to fix my problem? now funny thing is that I went to dvd.. and I tried letterbox and still and no matter what I choose it still comes out 4:3 Hmmmm..
    thanx in advance
