Copy paste effect keyframes loses effect attributes
When I copy keyframes for an effect and paste them onto another layer, AE pastes the keyframes and the effect, but the effect loses some of the attributes that were in the original effect. For example I’ll have a Tritone effect on one layer with keyframes that change the Blend With Original Opacity, and when I copy and paste those keyframes to another layer, the colors reset to their default black and white.
I know if I copy and paste the whole effect, it will maintain the attributes correctly. But it’d be nice to copy and paste other keyframes from one layer to another such as Transform properties along with the effect keyframes, and paste all of those at once onto another layer to easily maintain the keyframes’ timing. It’s a pain to copy and paste Transform properties, and then do another copy and paste for the whole effect, and then move those keyframes for the effect to line up with the transform properties. Seems like when you copy any type of keyframes, they should all paste without losing any attributes or resetting.
