Activity Forums Adobe After Effects copy motion sketch frames into WRITE-ON (position) offset?
  • copy motion sketch frames into WRITE-ON (position) offset?
    Posted by David Lieberman on March 13, 2008 at 6:21 pm
    hello,
    Im trying to motion sketch a shape that i’ve got. After I try to copy the position keyframes in order to paste them in the BRUSH POSITION value of the Write-On effect.
    Im basically trying to reveal the shape in that way, using writ-on. but when i paste the position frames onto the write-on brush position value, the entire sketch shifts about 15pixels to the right… I’ve tried every way of pasting it to fit the shape perfectly but it just wont happen…
    any ideas?
    thanx for the help.
    David Lieberman replied 18 years, 6 months ago 21,207 Members · 3 Replies
  • David Lieberman
    March 13, 2008 at 10:03 pm
    excellent. thank you very much!!
    thanx for the help.
  • David Lieberman
    March 14, 2008 at 6:05 pm
    i’ve tried the ammendments, made the layer same size as comp. still no hope…the line is less offset, but still off by at least 10 pixels.
    Could it have anything to do with the fact that i’ve got a dv pal comp with a square pixel layer? i’ve resized it by going to transform-fit to comp. is that wrong?
    thanx for the help.
  • David Lieberman
    March 14, 2008 at 7:49 pm
    heheh no no no NEVER…
    i know im pretty new to aspect ratios and sizes and all that but I DO know the difference between pal and ntsc.
    thanks for the tips mate!!
    dave.
    thanx for the help.
