Activity Forums Adobe Premiere Pro Copy master clip effect between master clips
  • Copy master clip effect between master clips
    Posted by John Kaley on September 16, 2016 at 4:17 pm
    I’m color correcting a program using master clip effects.
    Color correcting edits from the same take ripple though just fine.
    Now, I want to copy a Lumetri effect from a master clip to another master clip from a different take. Cannot find how to do this. Copy/paste attributes is not available.
    Simply, I want to copy effects from one master clip to another master clip from a different take. Gotta be missing something simple here.
    Felix Von nida replied 7 years, 6 months ago 4 Members · 4 Replies
  • John Kaley
    September 16, 2016 at 4:34 pm
    I found a clunky work-around.
    1. Select clip in timeline. Hit “F” to load into source monitor
    2. Select “Effect Control” tab. Right click effect to copy
    3. Select new edit in time time. Hit “F” to load into source monitor
    4. Select “Effect Control” tab. Paste effect.
    Hopefully this can be simplified!
  • Jim Townley
    September 19, 2016 at 11:47 am
    John,
    Do your color correction on the master clip, highlight the effect(s) in the Effect Controls tab, click on the menu bars and select “Save Preset”.
    It will save everything you highlighted. Go to your next master clip and drag that preset from the Effects Tab up the new master clip.
    Let me know if this is what you are looking for.
    Jim
    Jim Townley
    Television Production
    Chattahoochee Technical College
    Marietta, GA
  • Ann Bens
    September 19, 2016 at 8:48 pm
    Or copy/paste from one master clip to another master clip in the Effect Contols.
    Adobe Certified Expert Premiere Pro CS6/CC
    Adobe Community Professional
  • Felix Von nida
    February 11, 2019 at 7:38 pm
    Nice workaround, thanks Jim!
