Activity Forums Adobe After Effects Expressions copy keyframes via script
  • copy keyframes via script
    Posted by Jakob Schindegger on May 14, 2008 at 11:10 am
    hi
    i finished my script to convert one effect to another. in my case i needed to switch the 3rd party FE-Toner to the built-in Tritone Effect. Except the fact that i can only copy none keyframed effects it works like a charm. At least on my system.
    i am looking for a way to copy all keys of one property to another property using the script.
    is there an easy way to do that or do i really have to save every value of every keyframe and then create these values on the new property? does anyone has written a function doing that, he or she would share or maybe someone has a clue how to easily handle this problem.
    thanks in advance
    jakob
    before i posted it in the wrong forum. i hope that someone has an idea.
    Jakob Schindegger replied 18 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 14, 2008 at 2:30 pm
    I’m not aware of a general way to do this. I’ve always ended up writing a custom routine that takes advantage of whatever I know about the keyframes. For example if you know that all the keyframes are linear, you can leave out a bunch of stuff that you’d otherwise have to check for.
    Dan
  • Jakob Schindegger
    May 15, 2008 at 11:05 am
    Thanks Dan for the reply.
    It’s a pity that just copying keyframes can’t be done in one step. But after i figured out how the keyframe attributes work i could finalize my script. If i find the time i will pack it into a function.
    In case anyone is interested in a script which switches the FE-Toner to the built-in Tritone Effect, just reply to this post.
    jakob
