Activity Forums Adobe After Effects Copy keyframe data from AE to Premiere Pro?
  • Copy keyframe data from AE to Premiere Pro?
    Posted by Harris Majeed on June 29, 2017 at 4:36 pm
    Hello everyone.
    Is there a way to copy keyframe data from AE to Premiere Pro?
    Specifically; i’m trying to position keyframes. I tried saving the AE project as a Propj file but apparently it was saved in a newer version of Premiere Pro?
    Cheers!
    Michael Szalapski replied 7 years, 6 months ago 4 Members · 4 Replies
  • Harris Majeed
    June 29, 2017 at 4:57 pm
    I used Mocha to track some motion and i want to paste the keyframes in Premiere Pro. I know i can use Dynamic Link but i want to use the Titles i’ve made in Premiere (and refuse to use any other titler)
  • Alex Ezorsky
    January 7, 2019 at 3:26 pm
    You can copy keyframes from AE to PR! You can’t do it by copying and pasting the keyframes or properties (like you could in AE or PR) BUT you can copy entire clips from AE into PR! If the effects/properties you have in AE also exist in PR they will carry over with it!
    I was so pleased when I found this out via the famous Jarle at https://premierepro.net/jarles-premiere-pro-presets-version-4/
  • Amir Aizat
    March 13, 2019 at 2:16 pm
    Hey Alex, that’s a great help, I didn’t know we can do that.
    There’s a problem with the Scale keyframes though, any ease applied in After Effects won’t be imported (but the keyframes itself were imported). Do you know a way around this? I tried exporting as a Premiere Pro project in After Effects as well, but it gave me the same result.
    It’s a shame, it worked really well with Position and Rotation, but not Scale or Opacity.
  • Michael Szalapski
    March 13, 2019 at 2:21 pm
    Try saving your titles from Premiere Pro as PNGs and then animate them in AE.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
