Activity Forums Adobe Premiere Pro copy In & Out from sequence to another sequence
  • copy In & Out from sequence to another sequence
    Posted by Patrick Wright on January 30, 2012 at 11:15 am
    I’m day 3 cutting a feature doc in Premiere Pro. I’ve been a FCP cutter since day one. In FCP when I watch down a shoot I load all the material into a timeline so I can feel the event as it was shot. I pull selects by either copy and pasting between in and out points into a new selects sequence. In PP I’m having trouble doing this. Am I missing something. Clearly I can left or extract from a timeline between in & outs, but I want to copy into another sequence between in & outs.
    Also in FCP I could press the F key with the indicator on a clip in the timeline and the source clip would match frame into the Viewer with the original clip file. I could then in and out this clip. I can not find a compliment in PP. If I double click the clip in the timeline I get that clip in the source window (like FCP). I see that there is a reveal clip in Project which I can then double click. Would love it to be 1 step versus two. Also, when I do this it moves me away from where I’ve got the project window aligned….
    Regardless, so far I’m liking premiere. I was worried at first, but now I’m feeling positive!
    Dave Boyle replied 10 years, 12 months ago 8 Members · 7 Replies
  • 7 Replies
  • Kevin Monahan
    February 3, 2012 at 1:48 am
    Press M for matchframe. It’s the equivalent of pressing the F key in FCP.
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Jean Simenon
    February 22, 2012 at 9:22 pm
    Exactly what I’m trying to do as well. I have 3 tracks of video and 6 of audio. I have set the in/out points in the sequence, and now I just want to copy this and paste in the another sequence, or even in the same sequence.
    I don’t want to lift/extract, as I want to put that whole in/out section of the sequence into the clipboard.
  • Cognitive Films
    June 29, 2012 at 1:09 am
    I would like to do this as well… Cannot find solution. This was my usual workflow in FCP.
  • Kesten Migdal
    August 29, 2012 at 8:22 am
    I’ve searched for the copy solution to, but to no avail. It used to be ctrl+i and ctrl+o, then you could copy the selection in FCP. Maybe we need to do a feature request.
  • Jassin Kadiri
    August 15, 2013 at 4:08 pm
    Though this one´s older, some might still be looking for the solution:
    Just drag and drop the whole track from your sequence to your project tab. It´s gonna create a new clip of it, which can be edited just as always.
    cheers,
    AJ
  • Demetris Posnakides
    May 20, 2014 at 11:42 am
    Drag the hole sequence from project panel to source panel. Now you can set ins and outs and copy them to the timeline
  • Dave Boyle
    September 24, 2015 at 2:46 am
    Just stumbled on this. The easiest way is to use control/command+shift+k to cut all tracks at the theoretical in and out points. Then copy the segment. Then undo twice. The undo wont undo the copy but will get rid of the cuts. Now paste to the new sequence.
