Activity › Forums › DaVinci Resolve › copy grade timeline node
Posted by Israel Diaz on October 9, 2014 at 9:03 amHello I will like copy the grade in the timeline node not in the clip or put in the galley .
it is posible??
Thank you
Prathvish Hegde replied 11 years, 11 months ago 3 Members · 3 Replies -
Marc Wielage
October 9, 2014 at 10:04 amWell, you can copy grades with command-C or control-C and then paste them, if that’s what you mean. Do you mean one grade for the entire timeline? I have to admit, I’ve never tried copying a grade in that mode, but I bet it could be done. At worst, you could open up the node graph and drag over the specific nodes you wanted, if there was a reason for applying a grade to the entire timeline.
Israel Diaz
October 9, 2014 at 10:13 amOK I find the solution.
When you duplicate a timeline, the timeline node grade not past to the copy, you need select and save in a memory to paste to new timeline.
Prathvish Hegde
October 10, 2014 at 6:47 amColourTrance is the answer
prathvish hegde
colorist
(DaVinci Resolve and 2Kplus)https://www.youtube.com/playlist?list=PLRPJQ3fIEoojI3JMa4rHKb9gqq8VeIZ81
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
