Activity Forums Apple Final Cut Pro Copy from one Project and paste into a secondary storyline of another
  • Copy from one Project and paste into a secondary storyline of another
    Posted by Scott Witthaus on February 23, 2015 at 5:48 pm
    Ok, there has got to be a “vulcan grip” key combo to do this? As stated in thread title, I want to take a series of still images from one project timeline and paste into a secondary storyline of another. Ideas? Thanks in advance and apologies if this is really simple. Been a long couple of days….
    Scott
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
    Nick Toth replied 11 years, 7 months ago 4 Members · 6 Replies
  • Brett Sherman
    February 23, 2015 at 6:21 pm
    Cmd – Option – Up in the still image timeline to move them out of the primary into a secondary. Select the secondary timeline. Hit Command-C to copy, then paste into your main timeline. Cmd – Opt – Down in the still image timeline to move the clips back into the primary.
  • Nick Toth
    February 23, 2015 at 6:34 pm
    Select the still images. “Option G” to make them a compound clip. Go to the second sequence. Choose the compound clip in the event browser and use “q” to make an attached compound clip. “Command G” makes it a secondary storyline and then “Shift Command G” to break apart the compound clip. Takes longer to type out than to do it.
    anickt
  • Scott Witthaus
    February 23, 2015 at 11:20 pm
    Two great suggestions. I should have totally thought of the Compound Clip thing! Thanks all.
    Scott
    Scott Witthaus
    1708 Inc./Editorial
  • Nick Toth
    February 24, 2015 at 1:31 pm
    It never really occurred to me to use compound clips as a way to move large chunks of content around like this until I had been using FCP X for a while. That’s one of those things that’s difficult to teach or put into a manual unless you are doing it all the time. Glad to help!
    anickt
  • Eugeny Korkhin
    February 26, 2015 at 12:25 pm
    You can Cmd – C to copy and then Alt – V to paste as connected clips. But it does’t combine them into secondary, only connects.
  • Nick Toth
    February 27, 2015 at 6:46 pm
    W will insert into selected secondary at the position of the skimmer (if active) or the playhead
    anickt
