Activity › Forums › Apple Final Cut Pro Legacy › Copy from 23.98->Paste 29.97; Clips pasted out of order
  • Copy from 23.98->Paste 29.97; Clips pasted out of order
    Posted by Mike Kahn on April 20, 2010 at 9:14 pm
    This one is really confusing. I’ve copied and pasted from 23.98 to 29.97 and never had problems. I am trying to conform a project that was shot DV 29.97 and edited into a 23.98 HD project back to SD so I can put it through a terranex. I have seperated out the footage I need and when I paste it into the DV 29.97 sequence, it’s not matching up correctly. After looking into it further, some of the clips are being pasted out of order and throwing off everything after it.
    I have trashed prefs, reset permissions, etc, and it hasn’t fixed the issue. I also made a test sequence with 4 text slugs and they came across fine.
    This is a real headache if I can’t get it to copy and paste correctly. Anyone have a problem like this in the past? Any suggestions?
    DVCProHD 23.98->DV 525i29.97
    FCP 7.0.1
    Mike Kahn replied 16 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
