Activity › Forums › Apple Final Cut Pro Legacy › Copy FCP files to disc and use on another Mac
  • Copy FCP files to disc and use on another Mac
    Posted by Cjahrens87 on August 11, 2006 at 1:07 pm
    I want to copy my FCP file from my home computer an eMAc G4 I used as an offline editor. I want to use the copied file and recapture my footage at my office Mac a G4 Desktop system. I tried to make a CD and the file was corrupt. Is there any way to accomplish this task? Thanks for your help.
    cja
    David Roth weiss replied 20 years, 1 month ago 4 Members · 3 Replies
  • Bret Williams
    August 11, 2006 at 1:31 pm
    Done it many times. Email, CD, whatever. I think you might just be having a little bad luck. Make sure the work version is at least as new as the home version and try again.
  • Tom Matthies
    August 11, 2006 at 1:32 pm
    Are you copying the FCP project file? It should work. Are you running different versions of FCP on the two machines? It should still work unless the Office machine is running an older version of FCP. Then the file from your home machine won’t load. FCP projects are not backward compatable. If the CD files are truely corrupt, why? If the CD copy is bad, try to copy the project file to a jump drive type device and then transfer it to the other computer.
    Just a few thoughts early in the morning.
    Tom
  • David Roth weiss
    August 11, 2006 at 4:21 pm
    If you are exporting from FCP you must export a self contained QT.
