Activity Forums Adobe Audition Copy effects to multiple clips Audition
  • Copy effects to multiple clips Audition
    Posted by Patrick Gillespie on January 10, 2014 at 7:44 pm
    Hey-
    Desperately in need of some help. Working in premiere, we found a glitch in our recording system so that the phasing is inverted on one of our tracks. Seems like an easy fix- take it to audition, invert the phase, take it out. However, the problem occurs in almost every clip of audio in our feature length film. as ‘invert’ doesn’t appear on the effects rack, I am unable to copy/paste it to other clips easily.
    Is there an easy way to do this? I’m very much trying to avoid manually converting every single clip in the timeline.
    Pat
    Patrick Gillespie replied 12 years, 8 months ago 1 Member · 1 Reply
  • Patrick Gillespie
    January 10, 2014 at 8:54 pm
    Ok, solved the problem. Although I couldn’t copy and paste it as an effect, I recorded the entire process as a favorite and then performed the operation on a batch list.
