Activity Forums Adobe After Effects Copy composition so I can chage pictures and text
  • Copy composition so I can chage pictures and text
    Posted by Lars Gravesen on January 10, 2020 at 7:36 pm
    Hi I have a comppsition with animation of picture and tekst. Can I copy this an change the pictures and text and keeping the effects. If I copy a composition and change the pictures they are changed in the original too. how can I do this so that I can use the settings and not make everything again and again.
    Thanks so much
    Lars
    Drew Hutchison replied 6 years, 7 months ago 4 Members · 4 Replies
  • Walter Soyka
    January 10, 2020 at 8:37 pm
    You need to duplicate not just the one composition, duplicate and relink the comp and all the precomps that it relies on.
    Two options:
    1) True Comp Duplicator does this with just a couple clicks: https://aescripts.com/true-comp-duplicator/
    2) Manually, you can isolate the comp and all dependencies that you need, then reimport it multiple times into your project file. File > Save As…, and choose a new filename for your AEP. Select the comp you wish to duplicate, and with that selection choose File > Dependencies > Reduce project. This will remove everything from your project except the comp you selected and the items upon which it depends. Re-open your original AEP, then import the new reduced AEP to get the independent comp/precomp structure. You can re-import as many independent copies as you’d like
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Greg Gesch
    January 10, 2020 at 11:00 pm
    Hi Lars, select the composition in the Project Panel (usually in the upper left corner of your screen) and duplicate it – CTRL+D. You can then open the duplicate and change things in it without the original composition being affected.
  • Lars Gravesen
    January 13, 2020 at 3:13 pm
    HI Greg, Thanks so much this was the great way to do this.
    Lars
  • Drew Hutchison
    January 13, 2020 at 7:37 pm
    Adding onto this, if you want to keep the same effects on the same picture layer but replace the picture you can do this by simply clicking on the layer in your timeline, hold alt/option on a Mac and drag your new picture/asset from the project window onto your selected layer in the timeline. This will replace it with the new file but keep all effects the same on that layer.
