Activity Forums Adobe After Effects copy comp to multiple comps
  • copy comp to multiple comps
    Posted by Carlos Fonsalía on November 29, 2020 at 2:03 am
    <pre data-placeholder=”Traducción”>The thing is: I use the editmonkey script, it allows me to create multiple comps with text animations inside. Let’s say I create about 20 comps with animated text inside, then I create a comp where I insert adjustment layer for color effects, shadows, textures, etc. So what I’m looking for is to take this comp and insert it into those 20 comps with animated text inside, does it make sense? the goal is to have a “master comp” that contains the effects, and to be able to insert it in as many comps as I want, in this case the 20 comps with animated text…… and avoid copying and pasting one by one. is there any script or way to do it in after effects? thanks!
    Carlos Fonsalía replied 5 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
