Activity Forums DaVinci Resolve Copy clip burn-in attribute and paste to another clip – not possible?
  • Copy clip burn-in attribute and paste to another clip – not possible?
    Posted by Alex Golo on August 11, 2019 at 4:39 pm
    I have several clip with different burn-in custom text.
    I want to copy the same parameters to another clip but change the text later manually.
    I wanted to find a way to quickly copy burn-in attributes from clip to clip so that position/size and font of text will remain the same and I just change the text itself.
    Any ideas?
    Thank you!
    Glenn Sakatch replied 7 years, 1 month ago 3 Members · 2 Replies
  • Marc Wielage
    August 12, 2019 at 10:39 am
    I don’t believe there’s currently a way to do that, but it is a good idea and I wish you could copy those settings. Beyond writing the settings down manually, I have no other workarounds.
  • Glenn Sakatch
    August 12, 2019 at 1:55 pm
    Well you can certainly save them as a preset, and then manually change the custom text each time you call up the preset…depends if you are trying to batch things, or have different text for each clip…on which case you would need to save a new preset for each instance if differing custom text.
    Glenn
