Activity Forums Apple Final Cut Pro Legacy Copy Attributes Limitation?
  • Copy Attributes Limitation?
    Posted by Mark Fanjoy on December 5, 2011 at 7:03 am
    Copying attributes, specifically “Filters” seems to present a limitation, but maybe I’m missing something.
    I have a clip with two filters applied, a Key for manipulating the background, and a Color Corrector for the product in the clip.
    I want to copy and paste from that clip to another clip only the Color Corrector filter. But in the “Copy/Paste Attributes” function I only see a check box for “Filters”, which will copy BOTH filters. And I subsequently have to delete the unwanted filter from the target clip.
    Similarly, if say, a color filter is already on a target clip when I paste from a clip which also has a a color filter, the target clip will now have two Color Corrector filters and I have to delete one.
    Is this just the way it is, and I need to check every target clip and delete the unwanted filters and duplicates?
    Wherever I am…I’m lost!
    Mark Fanjoy replied 14 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
