Activity › Forums › Adobe After Effects › Copy and Pasting Mask onto another Layer
Posted by Wolfmandom on November 6, 2007 at 12:42 amAnyone know how to Copy and Pasting Mask onto another Layer?
thanks
Dominic Daniels
Todd Kopriva replied 18 years, 10 months ago 3 Members · 2 Replies -
Mike Clasby
November 6, 2007 at 6:22 amSelect the layer with the mask, M reveals the mask. Select the mask, Copy, Select the new layer. Paste.
If The masks are the same size, the mask will be the same. If the layers are different sizes things get a little wonky.
You can move and resize/rotate a mask (after pasting I mean) if you double click any mask vertex, then you get a little transform box like in PhotoShop to drag it around, resize, rotate (then hit Enter).
Todd Kopriva
November 6, 2007 at 6:30 amfrom the “Copy, cut, paste, or duplicate a mask” section of After Effects Help:
“* To copy or cut selected masks to the clipboard, choose Edit > Copy or Edit > Cut.
* To paste a mask onto a layer, select the layer and then choose Edit > Paste. If a mask is selected, this replaces the selected mask.”————————————————————————————————–
Todd Kopriva, technical editor, Adobe Systems Incorporated
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
How about taking a survey about After Effects documentation? Please?
