Activity › Forums › Adobe Premiere Pro › copy and paste transitions?
Posted by Nathan Quattrini on January 30, 2007 at 8:56 pmI also can`t seem to find a way to do this. I tried their help, but its less than helpful.
Mike Cohen replied 19 years, 7 months ago 6 Members · 5 Replies -
Mike Velte
January 30, 2007 at 9:21 pmIf you are madly in love with a particular transition, you can make it the “default” transition and apply it with CTRL+D at an edit point. Just right/click on the transition in the Effects palette and choose Default.
Steven L. gotz
January 30, 2007 at 10:12 pm -
Mark Perez
January 31, 2007 at 5:39 amI probably dont do this correctly but I created a 2 hot keys in preferences
1 is created as the (~ or ` ) key this I mapped to “next cut”
2 is created as the (1) key this i mapped as default transition(ex fade)now I just ~1 ~1 ~1 over and over, then flip the default trans when I want to do something else in massive amounts, You can edit 100 transitions via my method in 2mins no lie.
note the positions of the ~ & 1 key
set you work to video 1 for example then`1`1`1`1`1`1`1`1`1`1`1`1`1`1`1 look how many transitions i just created
Lloyd Coleman
January 31, 2007 at 9:47 amThat techique is pretty slick because the keys you choose are in a great location. However, there is a method that is almost as fast without having to assign hot keys. The ‘page down’ key will go to the next cut and the combination of ‘control+d’ will apply the default transition. To do this fast requires two hands, but it is as fast and easier than your method because you don’t have to assign keys.
Mike Cohen
February 1, 2007 at 10:40 pmI have kept the ctrl + d and page down method, because my brain is hard wired to do ctril + t which was the unchangeable media 100 transition shortcut.
I have assigned the W E S D keys to target higher and lower audio and video tracks, since my left fingers are always hovering around there.
