Activity Forums Apple Final Cut Pro Legacy Copy and Paste sequence, audio/video clips get out of sync?
  • Copy and Paste sequence, audio/video clips get out of sync?
    Posted by Jason Ferris on November 11, 2010 at 4:25 am
    I’m trying to copy an entire timeline into a new sequence. Basic, right? Well, when I paste the timeline into a new sequence, I get several problems. Spaces appear between video clips; audio clips become out of sync by 1 or 2 frames; the audio levels reverse themselves (where they are high in the source timeline, they become low in the new timeline and vice-versa).
    Does anyone know what’s going on here? If I don’t find a solution, I’ll have to go through and manually adjust everything again!!
    Thanks.
    Luke Milton replied 15 years, 10 months ago 3 Members · 3 Replies
  • Michael Gissing
    November 11, 2010 at 4:35 am
    Is the frame rate identical in both sequences? The gaps and shifts sound like what happens when 23.98 is pasted into 29.97 or vice versa.
    I don’t know what is happening with audio levels, but I suspect the clips are being trimmed which might delete critical keyframes, changing your levels.
  • Jason Ferris
    November 12, 2010 at 12:10 am
    Problem solved!! Thanks — it was indeed the frame rate.
  • Luke Milton
    November 17, 2010 at 10:22 am
    Dude you’re an absolute legend! I was having the same problem as Mr Ferris. I added a clip I made in AE and of course clicked yes to change the settings for ‘best performance’ but did it subconsciously lol.
    Thank you once again!
    Luke Milton
