Activity Forums Adobe Encore DVD Copy and paste menus with button routing?
  • Copy and paste menus with button routing?
    Posted by Ryan Antrim on March 26, 2010 at 7:33 pm
    Hi everyone,
    I am working on a project that is designed to work almost like a website, but on a DVD. There is a navigation bar with 8 buttons on it, plus a next and back button. There will end up being many pages (each page is a menu)with little if any difference in buttons and routing. The only difference will be the body text in the middle of each menu. So I made one menu, didn’t like the button routing so I turned off auto route and manually routed each button. Now I need to duplicate (copy/paste) the menu multiple times and keep the button routing from the original. The problem is when I copy/paste to make a new menu the button routing resets and all the buttons route to nowhere! I don’t feel like going through 50+ menus and manually routing each of the 11 buttons per page. Is there a way to duplicate a menu and have it keep the same button routing without having the auto route box checked?
    Ryan
    Jeff Bellune replied 16 years, 6 months ago 2 Members · 3 Replies
  • Jeff Bellune
    March 26, 2010 at 7:40 pm
  • Ryan Antrim
    March 26, 2010 at 8:56 pm
    Thanks.
    Is there a way to copy and paste whole folders including the contents?
  • Jeff Bellune
    March 26, 2010 at 9:52 pm
    Given the well-documented fragility of En projects when assets or folders are modified or moved outside of En’s built-in commands and operations, I would advise against it.
    That said, you could create a full copy of your project by doing a Save As operation, and then experiment on the copy without endangering the original project.
    -Jeff
    The Focal Easy Guide to Adobe Encore DVD 2.0
