Activity Forums Apple Final Cut Pro Legacy copy and paste marker
  • copy and paste marker
    Posted by Jan Stieler on July 2, 2008 at 11:53 am
    I have two masterclips. The first ist furnished with markers and I need now the markers on the second masterclip.
    Is there a way to copy and paste them into an masterclip? Also that FCP doesn´t create new supclips after pasting the markers.
    Greets
    Jerry Hofmann replied 18 years, 2 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    July 2, 2008 at 12:49 pm
    Just duplicate the clip with the markers. You should be able to drag a marker within a clip in the Browser to another location in the Browser, and a subclip should result. Or select it, and type cmd+u.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO, CD’s
  • Jan Stieler
    July 2, 2008 at 12:58 pm
    you missunderstood me. I don´t want to duplicate the supclips.
    I need the markerpositions from an masterclip in another masterclip (Soundtrack) with different content.
  • Lou Borella
    July 2, 2008 at 2:49 pm
    Jan
    FCP’s handling of markers is abysmal!!! It drives me nuts every time I have to make changes to a timeline that has markers in it and re-export to DVDStudio. You can’t move them around without using a keystroke and you can’t move them earlier in a timeline at all!!
    I tried different copy and paste tests to get markers from one clip to another and it doesn’t seem to work.
    I don’t think there is a solution to your question that is short of adding them again manually.
    Lou …
  • Jerry Hofmann
    July 4, 2008 at 2:14 pm
    You have me confused… you want markers in one clip to be copied to another clip that isn’t the same video? Don’t know of a way to do this at all. Why would you want to do this?
    Jerry
