Activity Forums Adobe After Effects copy and paste in&out points to multiple layers in diff comps?
  • copy and paste in&out points to multiple layers in diff comps?
    Posted by Danny Perez-triana on October 2, 2008 at 6:23 pm
    Hello, i have a precomp made of the same shot that lasts ten frames. i stagger them to every five frames, creating a loop or a constant stutter or the same image. so there would be say 30 layers of this shot adding up to about 5 seconds or something.
    in terms of using a different shot in a different precomp the same way, is there a way to just copy and paste the in and out points across two precomps?
    does this make sense?
    as always, i feel there must be a quicker way that i’m not aware of then manually entering the in points through a bunch of layers.
    i’m using CS3 pro.
    thanks for any advice,
    Ignacio
    Danny Perez-triana replied 17 years, 11 months ago 2 Members · 2 Replies
  • Jan Sherlink
    October 2, 2008 at 6:35 pm
    If you have one comp ready,
    Duplucate the comp, select the layers and drag your new media on it while holding the ALT key,
    that will replace the used media.
    or you can use the keyframe assistant > Sequence layers
    think that should help
    cya,
    Jan
  • Danny Perez-triana
    October 2, 2008 at 6:49 pm
    thanks so much! i’ll give it a try.
    ignacio
    dip
