Activity Forums Maxon Cinema 4D Copy and paste coordinates????
  • Copy and paste coordinates????
    Posted by Jason Coursey on May 16, 2008 at 3:47 am
    Hi, Cow.
    Is there a way to copy one objects coordinates (all of them – position, scale, rotation) and paste it into another without copying and pasting each and every parameter???
    I cannot find it for the life of me.
    Jason
    Adam Trachtenberg replied 18 years, 4 months ago 3 Members · 3 Replies
  • Adam Trachtenberg
    May 16, 2008 at 4:28 am
    No way to copy/paste that I know of, but the Functions>Transfer tool does exactly what you want. 😉
    AdamT
    Cinema 4DXL8 Bodypaint
    *Remember: Tues. is national Shoe Day. Wear shoes to show your support for bimetalism and the designated hitter rule!*
  • Brian Jones
    May 16, 2008 at 4:44 am
    Functions Transfer is the easiest but just for completeness…. Paste Identical ‘Suppose there are two cylinders in the scene. You select one of the cylinders, select its Radius and Height parameters in the Attribute manager and choose Copy to copy the two values. If you then select the other cylinder and choose Paste Identical, the two values will be pasted to the same parameters — Height and Radius — regardless of which parameters are currently selected. This is in contrast to the Paste command, which pastes to the selected parameters.’
    Which allows you to select any or all parameters common to objects and paste them all at once to others.
  • Adam Trachtenberg
    May 16, 2008 at 5:05 am
    I’ll be damned! Never knew about that “paste identical” command!
    AdamT
