Activity Forums DaVinci Resolve Copy and Paste Aspect Ratio
  • Copy and Paste Aspect Ratio
    Posted by Peter Brewer on December 10, 2011 at 4:16 am
    Does anyone know how to copy and paste attributes of one clip in the media pool to many at once? I need to change the aspect ratio on half the clips and am having to change them one by one. Also, if I set the zoom for one clip in the colour section, can I copy and paste that to other clips?
    Peter Brewer
    http://www.indimax.com.au
    Peter Brewer replied 14 years, 8 months ago 2 Members · 2 Replies
  • Charlie Edison
    December 12, 2011 at 1:41 am
    two ways to do this,
    under session in the top menu bar, select ALL/COLOR/PTZR until PTZR is highlighted green in clip mode,
    then right click a clip, memory or still and show node graph.
    then top right menu of that window shows apply PTZR, this only works on one shot at a time unless you first make a group.
    you can then use ripple value, you’ll need to read the manual to too lengthy to explain, but with ripple value you can select a length of clips, ( e.g. 10,13 ripple value) to append or replace the PTZR settings to clips 10,11,12,13
    ripple value can be a little challenging to get your head around, there are four different modes listed in the config page under settings that have different impacts on the results.
  • Peter Brewer
    December 13, 2011 at 2:02 am
    Thanks for the info Charlie. I’ll give it a shot 🙂
    Peter Brewer
