Activity Forums Avid Media Composer Copy and past column data to another column
  • Copy and past column data to another column
    Posted by Scott Davis on May 8, 2015 at 3:16 pm
    I was shown at one point how to copy an entire column’s data to another column. For the life of me I can not remember how to do it. Any ideas?
    Scott Davis
    View Scott Davis's profile on LinkedIn
    Scott Davis replied 11 years, 3 months ago 3 Members · 4 Replies
  • Michael Hancock
    May 8, 2015 at 3:29 pm
    Select the column header , hit Cmd/Ctrl+D, pick the column you want to copy it to and hit OK.
    Michael Hancock
    Editor
  • Scott Davis
    May 8, 2015 at 8:10 pm
    Michael, thanks. It doesn’t seem to be working. I am on 8.3.1 if that maters. What is “ok” mean.
    Scott Davis
  • Michael Phillips
    May 8, 2015 at 11:26 pm
    What part is not working? The entire column will highlight, then do a command-D or control-D and a dialog box pops up with a list of columns. Select, click OK. Not all columns are equal, an obvious one is copying comments to a timecode column for example.
    Michael
  • Scott Davis
    May 9, 2015 at 1:26 pm
    Michael, The part that is not working is the guy behind the keyboard. I was hitting “control” and “command” and “D” and nothing was happening. When I hit just”command” and “D” it works perfectly. Thanks so much.
    Scott Davis
