Activity Forums Adobe After Effects Copy and change a Text comp
  • Copy and change a Text comp
    Posted by Dennis Jay on February 23, 2009 at 2:58 pm
    Need Help with a Text Proj
    well it propably is totaly easy but i cant do it.. 🙁
    all i want is in my existing composition wich has a backround text an emitter.. and a wiggle addet to the text.
    what i want is make a copy of that text “and the emiter” and have it apear just after the first text apears.. but if i change the “copy” it also changes the text in the first composition..
    does anyone have a clue what im doing wrong?
    sry for my bad spelling..
    Roland R. kahlenberg replied 17 years, 7 months ago 3 Members · 3 Replies
  • Jeremy Allen
    February 23, 2009 at 4:08 pm
    Are you duplicating it in the comp timeline, or in the project bin?
    If you duplicate in the timeline, you are making an exact copy, so anything you change in the duplicate will be reflected by the original comp.
    If you duplicate in the project bin, you are creating a new instance of the comp, and any changes you make to the duplicate will not affect the original comp.
    I think that’s right anyway.. Hope this helps.
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.2
    DualCore G5 2.0 GHZ, 2GB RAM, OSX 10.4.11
    AE CS3
  • Dennis Jay
    February 23, 2009 at 4:15 pm
    i duplicatet it in the projet bin the moved it down into the timeline.. changed the text and it still affectet the oter composition..
  • Roland R. kahlenberg
    February 24, 2009 at 5:54 am
    This doesn’t sound right. Perhaps you’ll want to post teh AEP up for someone to dowload and take a look. If you do so, please specif the AE version.
    Cheers
    RoRK
    broadcastGEMs – AEPro Volume 02 (Professional Adobe After Effects Project Files – Now Available)
