Activity Forums Adobe After Effects Coordinates problem when transfering from Cinema 4D to AE
  • Coordinates problem when transfering from Cinema 4D to AE
    Posted by Tornike Gelashvili on November 21, 2007 at 9:27 am
    Hello,
    I’ve imported Cinema 4D scene into AE. Everything works fine, but I have faced a little problem here.
    I want to paint on the walls and floor of the imported 3D scene (with camera motion) in after effects.
    I want to overlay some strokes and coulds and some extra stuff with animation.
    The problem that I’ve faced is coordinates. Let’s say I create a solid and paint some strokes on it, then I switch 3D layer switch and now I have to position thie layer in 3D space so that it matches up with the scene and doesn’t mess up while camera is moving.
    How should I determine the coordinates, where I should place this 3D layer?
    Or is there any other way to paint on 3D scene in AE that I might have overlooked?
    Thank you.
    P.S. I thouht Importing from 3DS Max (RPF) instead of C4D, but I might face the same problem.
    Tornike Gelashvili replied 18 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
