Activity › Forums › Maxon Cinema 4D › Coordinates for View
  • Coordinates for View
    Posted by Kelly Johnson on August 24, 2005 at 5:01 pm
    I’ve got Cinema4D version 8 at my office.
    Is there any window or way to tell what my view plane is at in terms of angles/tilt/ etc?
    For instance, I notice when I hold down the command key and the number 3, it allows for the “Dutch tilt” view (I’m on a Mac) but after I’ve been rotating the object itself as well and changing views even changing to “Front View” and then clicking on the object and setting the XYZ and HPB to 0 degrees, the view still doesn’t look like it’s square on.
    Kelly Johnson replied 21 years, 1 month ago 2 Members · 2 Replies
  • Björn Marl
    August 24, 2005 at 7:37 pm
    create a camera and take a look at it’s parameters. A newly created camera will use the current viewport as default.
    Cheers
    Bj
  • Kelly Johnson
    August 25, 2005 at 5:16 am
    excellant. Thanks!
