Activity › Forums › Maxon Cinema 4D › Coordinates dialogue and object coordinates still don't jive
Posted by Steve Bentley on September 19, 2021 at 10:37 pmCan some one tell me why (or tell me how to fix this) the coordinates dialogue goes: Position, Size, Rotation, but the Objects dialogue box goes Position Rotation Scale?
Sorry if I’m missing the vital intricacies of UI design here. Or should I just cross my eyes?
Jim Scott replied 4 years, 12 months ago 3 Members · 5 Replies -
Jim Scott
September 20, 2021 at 2:09 amThe “why?” is because they want to mess with your head. I’m guessing that is a change in R24, because I don’t remember seeing a prior version (at least through R22) that had the Objects dialogue box in that order. Unless I’m losing my mind it’s always been PSR as pictured below. And I don’t know of any preference setting to change it.
Steve Bentley
September 20, 2021 at 2:30 amOh good – at least it’s not screen dependent dyslexia. I can now officially call this dumb.
Thanks for the sanity check.
Steve Bentley
September 20, 2021 at 2:33 amHow did you add that image so nice and clean? Mine gets cut off by the image box in the Cow (which hides the header of the dialogue I was trying to show). Maxon isn’t programming the Cow now are they?
Zeyd Ayoob
September 20, 2021 at 7:35 amAlso see absolutely no reason for this. I can tolerate sudden interface changes if they are either explained, or obviously beneficial. This has just been dropped on us without any care taken, as I can see.
Jim Scott
September 20, 2021 at 2:01 pmI just hit the camera icon at the bottom of the reply window and dragged the screenshot into the resulting box. I think because it was a small screenshot it didn’t get cut off like larger ones will. The COW’s upload and display process has changed over the years and is sometimes less than optimal.
