Activity Forums Maxon Cinema 4D Coordinate Windows?
  • Coordinate Windows?
    Posted by Jon Herron on March 10, 2006 at 6:09 am
    Whats the difference between the two different coordinates windows? There’s one in the attribute window and the other one
    thanks
    jon
    Jon Herron replied 20 years, 5 months ago 3 Members · 7 Replies
  • 7 Replies
  • Björn Marl
    March 10, 2006 at 8:30 pm
    Different to the AM the coordinates manager can work with points, polygons and edges and is able to switch between world and local coordinates.
    Cheers
    Bj
  • Jon Herron
    March 10, 2006 at 8:36 pm
    Ahh I see, thanks
  • Jon Herron
    March 10, 2006 at 9:21 pm
    I cracked open the manual and started reading about the coordinate system a little more. They mention the HPB system which you can choose in the preferences. Something I never knew. But it keeps mentioned which coordinate system to choose. I assume local and world, right? Whats the difference between using local and global, should there be a change the object axis or something?
    thanks jon
  • Björn Marl
    March 10, 2006 at 9:30 pm
    All coordinates you see in the AM are local. This means they are relative to the parent. If the object is on root level then the local coordinates are identical to world coordinates.
    Example:
    Create a cube and a pyramid. Put the pyramid under the cube as a child. Then move and rotate the pyramid a bit. Now select the cube and move and rotate it too, but not identical to the pyramid.
    You will notice that the pyramid will follow the movements of the cube and stay in the same relative position. This relative position/rotation are the local coordinates.
    In the coordinates manager you can choose between local or global coordinates. Select the pyramid and have a look at the CM. Change between local and global display for the CM and watch the change in values.
    Mathmaticaly the global position of the child is the local position vector of the parent plus the local position vector of the child.
    Cheers
    Bj
  • Jon Herron
    March 10, 2006 at 10:14 pm
    So this only work with a child parent situation?
  • Nolan Scott
    March 10, 2006 at 11:37 pm
    Please have a look here:
    https://www.c4dcafe.com/ipb/index.php?download=226
    Cheers
    Nolan
  • Jon Herron
    March 11, 2006 at 2:11 am
    Perfect guys thanks!
