Activity › Forums › Apple Final Cut Pro Legacy › Cool time lapse
Cool time lapse
Posted by Zeke Meginsky on August 16, 2011 at 12:00 pmI want to do a short time lapse. The camera was really still looking down at a far away town with moving cars, etc. I’m wondering what I might do to make it look interesting (obviously other than up the speed in FCP to 300 or 400%)?
Christopher Travis replied 15 years ago 8 Members · 11 Replies -
Jerry Hofmann
August 16, 2011 at 12:10 pmTime lapse is nothing more than speeding up time by making the clip play faster, or by taking single frame exposures at less than 24 or 30 fps… so speeding up the footage will simulate a time lapse exposure. Don’t think there’s a “better” way to do this.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Zeke Meginsky
August 16, 2011 at 12:22 pmI was wondering if there was any effects that might make it look interesting.. like is there a blur, etc..
Jerry Hofmann
August 16, 2011 at 12:37 pmDon’t think a blur would do much but soften the picture. If you wanted the car lights to say trail or something, you need to actually shoot it with a long exposure to get that effect I’d think. Few if any video cameras can do this. Film cameras can. DSLR’s probably could pull this off too. I think that’s what you’re after, right?
Jerry
Current DVD:
Zeke Meginsky
August 16, 2011 at 12:46 pmYeah, that would have been good. It was just shot with a DV camcorder. So I guess the only thing I can do to make it look interesting is speeding it up.. thanks.
Rafael Amador
August 16, 2011 at 1:10 pm[zeke meginsky] “It was just shot with a DV camcorder”
Try setting the shutter-speed to 1/30 or 1/15 instead of the default 1/60 (asuming you are in NTSC-land).
rafael -
Mark Suszko
August 16, 2011 at 1:51 pmYou can apply simulated a tilt-shift lens effect to the existing time-lapse footage, which tricks the eye into thinking it is looking at a tiny model instead of real life… There are plug-ins for this, but you can pretty easily make it from scratch yourself.
Basically, you copy the footage to a second track, stacked in synch with the original. You apply some amount of gaussian blur to the new track and in between the two tracks goes a gradient filter applied to the alpha channel. You will have to play with the positioning and other controls for the gradient, as this will change the overall effect. For more hints, check youtube for tilt-shift effect videos.
Tony Brittan
August 16, 2011 at 3:40 pmCrumplepop has a plug-in called Shrink Ray that does a great job of adding tilt shift to your video.
Tony Brittan
Kent Beeson
August 16, 2011 at 5:05 pmIn addition you could also add motion blur to the shot (once its sped up) in FCP under MOTION tab, then Motion Blur, play with the settings to taste.
K
http://www.effectivevideo.net -
Chris Wiggles
August 17, 2011 at 10:08 pmThings like motion trails might be neat, etc. Lots of things to play around with.
I’ve had really neat effects with sunsets doing chunks of footage with fades to create a time-lapse without speeding up the footage ridiculously which looks dumb IMO.
Regards,
Chris
