Activity Forums Adobe After Effects Cool looking inserts
  • Cool looking inserts
    Posted by Tony Luke on April 14, 2009 at 4:12 pm
    Hey everyone,
    I was checking out this music video: https://www.youtube.com/watch?v=4DQWvOM5sUQ
    Thought it had really cool inserts like at 01:03 – lots of all around simple but cool effects. Anyone know where similar effects like these are coming from? I imagine they’re some sort of plugins?
    Mark Fogarty replied 17 years, 4 months ago 3 Members · 2 Replies
  • Dino Muhic
    April 14, 2009 at 5:58 pm
    This are film footage dropouts, the frames on a film roll where the cutter wrote some text on it or which were not developed correctly. You can try to find some old film footage, 8mm, 16mm, 35mm, doesn’t matter and project it with a strong beamer on a wall and capture it. Then just place it over your footage with the Screen or Add blend mode.
    Or you just take some typo, fill it with a strong magenta or cyan color and animate it over your video, and composite with the Add blend mode.
    I would prefer the realistic film footage thou, because you also get the dust & the scratches.
    If you want to produce the damaging with Plug-Ins check out Magic Bullet MisFire
    Dino Muhic – Media Producer
    VFX – Motion Graphics – Web-Design – Or just ART
    http://www.dinomuhic.com
  • Mark Fogarty
    April 14, 2009 at 6:23 pm
    Tony
    It could be a plugin but you can easily create a similar look without a plugin. Here’s what I would do (although I’m sure there are 17 better ways).
    Create a text layer and type a character… any character, using a font/symbol set you like the look of. In the example you showed, it looks like there are several characters in a vertical line, so perhaps type a character, hit return, type a character, hit return, etc…
    Twirl down the layer properties, than twirl down Text.
    Click on the Animate flyout and select “Character Offset”.
    Keyframe the Character Offset so the values of the characters you’ve typed change every frame (or however rapidly you want them to). Somebody will probably suggest an expression you can use to do the same thing… I’m as sharp as a marble and don’t know much about expressions.
    I would suggest creating this text layer as a separate comp, perhaps called “Flicker text”. Now, whenever you want that effect simply add that comp above your video layer and start messing around with the text color, transfer modes, opacity, scale, position, maybe even a bit of fast blur, to get the look you want.
    On your example it seems like not only are the characters changing, bu their position is dropping vertically. Simply keyframe the “Flicker text” comp’s position to do that.
    That’s what I would do, hope it helps.
    Mark Fogarty
    Media Missionary
    Muddy River Media
    http://www.MuddyRiverMedia.org
