Activity › Forums › Adobe After Effects › Cool effects using a path?
  • Cool effects using a path?
    Posted by Kit Carson on September 12, 2016 at 11:41 am
    I have this path of the FILA logo
    I am using stroke to trace around the outline, are there any other effects or techniques I can use to make use of the path? The client would really like to get a 3D effect inside the F, but any cool effects using the shape will work!
    It’s for this projection mapping installation in a store:
    Thanks for any help!
    Kalleheikki Kannisto replied 10 years ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    September 12, 2016 at 1:41 pm
    You can do more with the shape layers, such as animating the trim paths value with a filled shape.
    You can wiggle paths.
    You can duplicate the path and offset it in the Z axis for 3D-type effects.
    If you copy the mask path to a null as a motion path, the possibilities become almost endless. You can animate any object to go around the shape, or a light, or a particle emitter.
    Senior Graphic Designer
