Activity Forums VEGAS Pro Cool effect! Can Sony Vegas?
  • Rob Strobbe
    August 7, 2009 at 3:19 am
    “Does anyone know if it can be done with Vegas Pro?”
    Not with Vegas alone. The technique is called “morphing,” and it involves setting up points on two or more images / videos and telling the software which areas one one should “morph” into which areas on the next. Far as I know, there is no “magic” way to set up such an animation. It is painstaking work — especially if you want it to look really good.
    Search for “morphing software,” and you will find lots to choose from — all the way from free to hundreds of dollars. If you want to work inside Vegas, there is a program called WinMorph that can be used as a standalone as well as a plugin that works in Vegas. Though I’m not sure which is the most current version it works with.
    Rob
  • Diego Solis
    August 7, 2009 at 9:03 pm
    Thank you!
    Although it seems difficult to do I think I will download WinMorph and give it a try. Thanks again for the information.
    Diego
