Activity › Forums › VEGAS Pro › Cookie cutter creates artifacts, what to do?
  • Cookie cutter creates artifacts, what to do?
    Posted by Jaanus Henno on November 3, 2012 at 3:35 am
    Hi!
    I’m using cookie cutter to brighten certain area of a video, face of a dancer, and it moves along her. But when I added the effect and did my render, two layers look out of sync. But they are in sync and I specifically rendered without CC to check it. Why is that? I also tried rendering as 32 bit floating point as suggested on another thread but no success. The results are frustrating (although funny;-)).
    What to do?
    Steve Rhoden replied 13 years, 10 months ago 2 Members · 5 Replies
  • Steve Rhoden
    November 3, 2012 at 5:53 am
    Funny indeed, which version of Vegas is it?
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    1-876-832-4956
  • Jaanus Henno
    November 3, 2012 at 8:36 am
    You made me look into it more deeply and Vegas is not at fault, it’s the Neat Video plug-in what creates the artifacts. It’s not so bad (but still unusable) when added to the lower layer, but when I add it to upper layer, then it’s really bad.
    I guess I can prerender those parts with CC into Avi clips and add them to the project again. Waste of time, energy and quality.
  • Steve Rhoden
    November 3, 2012 at 11:06 am
    I see, you forgot to mention that you also used Neat Video.
    Yes, it will put your work out of sync if not handled properly.
    Its due to Temporal filtering, with a limitation of the Vegas
    plugin architecture. Its been a long debate about this
    and recent versions added a specific “No Lag Mode” feature
    to compensate.
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
  • Jaanus Henno
    November 3, 2012 at 11:41 am
    Thanks a lot Steve!
    That solved it, ticked the ‘no lag mode’ and everything is ok.
    Is that the only situation it’s useful or should I just keep it on all the time?
  • Steve Rhoden
    November 3, 2012 at 12:24 pm
    Keep it on all the time!
    Steve Rhoden
    (Cow Leader)
    1-876-832-4956
