Activity Forums Apple Final Cut Pro Legacy converting/playing .dv clips to quicktime
  • converting/playing .dv clips to quicktime
    Posted by Paula Stein on January 17, 2008 at 2:30 am
    A client sent me 2 clips that are in .dv format.
    I am unable to open them or convert them in quicktime so I can edit with them in FCP.
    Thx for your help.
    Paula
    “A journey of a thousand miles must begin with a single step.” ~Lao Tzu
    Paula Stein replied 18 years, 8 months ago 2 Members · 6 Replies
  • Jeremy Garchow
    January 17, 2008 at 3:28 am
    What happens if you change the suffix to .mov?
  • Paula Stein
    January 17, 2008 at 3:59 am
    I just tried it, changed .dv to .mov and it asked if I wanted to and I said “yes” and unfortunately,
    it still would not open.
    drag..
    any other ideas?
    Thx
  • Jeremy Garchow
    January 17, 2008 at 2:06 pm
    Yes, two. Open it iMovie (i think that’s where .dv files come from) or try MPEG Streamclip. It’s free. What’s weird is that it should open in QUicktime. There might be something wrong with the files themselves. How big are they?
    Jeremy
  • Paula Stein
    January 17, 2008 at 5:27 pm
    Jeremy,
    I tried to drag and drop the file into MPeg Streamclip already.
    Do you happen to know the right procedure? The files are small clips (2 min each).
    Never even tried iMovie. The files came from a DVD.
    I really appreciate your help.
    Thank you,
    Paula
  • Jeremy Garchow
    January 17, 2008 at 5:34 pm
    What I meant was, what are the file size of the clips?
    Dragging and dropping should work with MPEG Streamclip.
    I am beginning to think that your files are bad.
  • Paula Stein
    January 18, 2008 at 5:46 pm
    I think you’re right the .dv files are ng,
    MPEG Streamclip would not let me drop the files in.
    I ended up getting the original file from the clients machine.
    Thanks again for your help!
    Paula
