Activity Forums Apple Final Cut Pro Converting xml file from Premier to FCPx ads a .mov extension to all video clips and duplicates those in library.
  • Converting xml file from Premier to FCPx ads a .mov extension to all video clips and duplicates those in library.
    Posted by Zack Starr on February 11, 2016 at 4:08 pm
    When my editor sent back an xml file from Adobe Premier, I had to run it through the 7toX app to allow my FCPX program to import it. The timeline is there but it duplicated all of our video clips into the library with a new .mov extension to them. Now the timeline is searching for the .mov files (that don’t exist on my computer) so all of those clips say “Missing File”. In the library there is the original clip (P6080143) and a second clip (P6080143.mov) that the timeline is using. How do I change the timeline to search for the original clips that do not have the .mov extension? Is it something I did wrong in the import process or does Premier change the file extension?
    Jeff Kirkland replied 10 years, 7 months ago 4 Members · 3 Replies
  • Noah Kadner
    February 12, 2016 at 2:56 am
    I’d suggest sending an email to the 7toX developers. It’s a pretty inexact science you’re working with there.
    Noah
    FCPWORKS – FCPX Workflow
    FCP Exchange – FCPX Workshops
  • Oliver Peters
    February 12, 2016 at 1:57 pm
    [Zack Starr] “that don’t exist on my computer”
    They should exist. If these are QT files they are .mov. It’s merely that the extension has been set to be hidden or that FCPX ignores or hides the file extension.
    [Zack Starr] “or does Premier change the file extension”
    Premiere isn’t changing the file extension. It’s merely using the full file name, including the existing extension. Like Noah said, contact Intelligent Assistance. There may be a way to strip off the extension in some manner so that FCPX recognizes the correct file.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Jeff Kirkland
    February 14, 2016 at 9:33 pm
    Or you could probably just load the xml into a text editor and do a search/replace to remove the .mov extension from the file names.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
